How It Works
Storage efficiency in Nutanix disk calculator
Trailblazer
In the nutanix disk calculator  http://designbrewz.com/ Can anyone please advise
what is storage efficiency ?
Is it related to the deduplication ,compression ,ecx etc?
By default its having 1.5X.For the storage calculation which option we should select?
Thanks in advance
rgds
Ritchie James
Tags (1)
Community Manager
Re: Storage efficiency in Nutanix disk calculator
Hi @alunkal
Let me see if I can get you a reply on this. -- Thanks
Community Manager, Nutanix
Community Manager
Hi  @alunkal
I was able to get you an answer from the team - 'storage efficiency' is related to dedup and compression.
Tags (1)
Trailblazer
Dear @aluciani Thanks for the reply,
But  by default its 1.5x is coming.
Can you please advise what is the difference between 1.5x and 2x.
Community Manager
Hi @alunkal - Let me get back to you on that, Thanks
Community Manager
Hi @alunkal
Essentially, it is the benefit from compression and dedup. At an average, we see between 2:1 and 1.5:1 ratios after storage efficiency. Depending on workloads, it could be a high as 8:1 or no benefit if the workload is already compressed and deduped.
Scout
can you please let me what are the typical ratios for different types of workloads
