How It Works
Missing options in Prism when hypervisor is ESX
SOLVED Go to solution
Explorer
Hi all, I have notices that when it is used ESX as hypervisor, there are a lot of stuff in Prism that are missing.... Like: - Image service to upload images - option (button) in VM screen to move (migrate) data from one host to another So If I am correct, based on my research, in this situation only solution is to use native VMWare tools like vCenter? Tnx!
1 ACCEPTED SOLUTION
Accepted Solutions
Guardian
Re: Missing options in Prism when hypervisor is ESX
That's correct.  While Prism now has more VMware CRUD operations inside Prism, it doesn't completely erase the need to go into vCenter.
I would put a request in for the migration piece.
1 REPLY
Guardian
