How It Works
Error from NCC on NGT ca.tar
SOLVED Go to solution
Trendsetter
I see the following from ncc health checks on our secondary cluster that has been recently updated
The primary cluster does not have the same fault
ncc output fail:
FAIL: /home/ngt/ca.tar does not have the same checksum on all CVMs.
Across the secondary cluster there  is a difference on each ca.tar
-rw-r-----. 1 ngt ngt 61440 Jul 7 2016 /home/ngt/ca.tar
Connection to ~.51 closed.
================== xxx.xxx.xxx.52 =================
Connection to ~.52 closed.
================== xxx.xxx.xxx..53 =================
-rw-r-----. 1 ngt ngt 61440 Aug 12 2016 /home/ngt/ca.tar
Connection to ~.53 closed.
================== xxx.xxx.xxx.54 =================
-rw-r-----. 1 ngt ngt 61440 May 10 16:47 /home/ngt/ca.tar
How best to clear this event?
1 ACCEPTED SOLUTION
Accepted Solutions
Re: Error from NCC on NGT ca.tar
Hi @roberthwl
This issue occurs when md5sum doesn't match of ca.tar on all the nodes of the cluster.
You can verify the md5sum from this command:-
allssh 'sudo md5sum /home/ngt/ca.tar'
Resolution : - ssh to the CVM containing the reference ca.tar file that you want to copy across the other CVMs for which md5 sum is not matching
You need to delete the existing CA.tar in the CVM before copying it .Make sure you can't copy directly in /home of the CVM  from other CVM so you need to create a tmp folder and scp to the tmp folder from other CVM.
After completing this, you can copy locally from  /tmp to  /home/ngt
Tags (1)
@roberthwl
This alert triggers due to an MD5SUM mismatch of the CA.tar file across the cluster.
Please raise a support case so that we can assist you over WebEx.
Sandeep MP
Hi @roberthwl
Tags (1)
