How It Works
Data movement from EMC VNXE3100 to Nutanix
SOLVED Go to solution
Moderator Moderator
Moderator
Re: Data movement from EMC VNXE3100 to Nutanix
hey @ashishs - We're happy to help out with this via our PS team if you'd like, as we do this exact thing all the time in customer PS engagements to design your specific environment.
Otherwise @magander3 is right, without knowing all of your requirements, its hard to definitively say exactly the right configuration for you. In general, more vDisks are preferred, but you also dont need to micromanage vDisks down to an ultra granular level. For a large file server, I'd roughly say 5-10 vDisks per VM.
Also, feel free to scale out the number of file server VM's you have, so that things like backup and recovery are easier.
Jon Kohler | Technical Director, Engineering, Nutanix | Nutanix NPX #003, VCDX #116 | @JonKohler
Please Kudos if useful!
Outrider
Jon, currently we are using EMC VNXE3100 and have 7 shares of total 30 TB...attached screen shot of shares size...
Please let me know how many vms i need to create and how many drives i can assign per vm....?
unless we get the information i was talking about we can't make any recommendations. Please engage Nutanix Services for a complete desig or use the guidelines me and Jon have provided to test different setup options.
//Magnus
Moderator Moderator
Moderator
hey @ashishs - Magnus is correct here, its hard for us to tell you exactly what to do, besides the general guidance that we've already given you.
If you want us to do the work for you, we're happy to do that via our great professional services team. They literally do these exact types of migrations every single day, and can be engaged on a paid basis to do the work on your behalf.
Also, I dont see a screenshot attached here.
Outrider
Below is the screen shot of the current shares on EMC.....
please use our provided general recommendations and try your way forward or if you want a complete design you need to engage Nutanix services. We can not design a proudction environment in a cummunities thread.
thanks
Outrider
Gyus, Thanks for support. I wnat to update you we have successfully migrated 30 TB data from EMC VNXE3100 to Nutanix with existing settings i.e rights
Used robocopy for the same.
Again thanks for the support.
ok sounds great. Good job
Moderator Moderator
Moderator
Great to hear @ashishs. What file server design did you end up going with? Server OS, number of vDisks, etc? Would be good for others who find this thread in the future
Outrider
Its simple file server, where around 200 users accessing their files. Usres are mainly used excel, word files. Server config is 4vCPUs, 16GB RAM, 6TB vDISK (Used space 3.2TB)
