How It Works
Alert issue via syslog message or another
Adventurer
In addition , Issues alert via Prism Dashboard and SMTP.
Nutanix Can be alert via syslog message (to SIEM) or another?
Thank you.
Tags (4)
Chevalier
Re: Alert issue via syslog message or another
Tags (4)
Community Manager
Hi @komdet Did the reply from @bezeddin help?
If you find an answer helpful, consider marking it as 'Accept as Solution.' Marking a reply as an accepted solution helps our community identify content that solves users’ problems.
Community Manager, Nutanix
Tags (4)
Adventurer
I config the rsyslog to remote syslog with all module (prism , cassanda , genesis , syslog_module , ...) follow
https://portal.nutanix.com/#/page/docs/details?targetId=Advanced-Admin-AOS-v50:Advanced-Admin-AOS-v5...
It works to send syslog message to remote syslog server
 but there isn't the Alert message like the Prism Dashboard.
Is there another way?
