HomeLab Setup
Mobile Home Lab
Journeyman
Mobile Home Lab
Here's a link to the story of building the version one of my mobile home lab with 8 server nodes and a master node for holding the sources and VMs for automating the builds:
https://www.infrageeks.com/blog/my-new-mobile-lab
All in one lab with a converted PSU to drive all of the components (except the HDMI switch) so that it runs off a single power cable.
And a pic of the version 2 where I replace the passively cooled MiniPCs with 32 Gb Gigabyte BRIX boxes. Using the vGhetto driver for the USB-C Ethernet adapters so that every machine is dual-ethernet for testing redundancy and failover behavior...
Trendsetter
Re: Mobile Home Lab
Amazing, we had the same idea Smiley Wink
Journeyman
Re: Mobile Home Lab
Yours is much more portable than mine. Curious if keeping the NUCs in the mousse poses any heat or airflow problems. I went with custom brackets to keep the interior as open as possible.
Trendsetter
Re: Mobile Home Lab
Yes, this is also something that I'm monitoring, I see heat .... I feel heat but I need to make some more test like a full day operating with measurements ...
