Get Started
need to config dot1q trunk for bond0 interface or not?
SOLVED Go to solution
Wayfarer
Picture1.pngmy question is form this senario
if host "VM1" belong to vlan 10 and host "VM2" belong to vlan 20
"CMV"&"AHV" on vlan 1 (untag)
i need to config trunk on bond0 interface or it done by automatic?
1 ACCEPTED SOLUTION
Accepted Solutions
Re: need to config dot1q trunk for bond0 interface or not?
The bond is configured as a trunk automatically.  You will only have to create the vlan 10 and vlan 20 networks in AHV then forwarding will work as expected.
Wayfarer
thx for you suggesstion.
