Backup and Recovery
What are you using for backup Nutanix?
SOLVED Go to solution
Explorer
Re: What are you using for backup Nutanix?
We currently use Veeam but we are going to try the Rubrik appliance
FIG
Wayfarer
Is Veeam and AHV combination is not working?
Explorer
Veeam is a good solution.
Waiting for the announced version of Veeam for AHV, we want to evaluate another solution before making the final choice ( We are also following the HYCU solution that seems very interesting).
Certainly veeam, for now, is our first choice.
FIG
Wayfarer
Yes, Veeam is good, we currently use it and are happy with it. Waiting for the release and annoucnement from Veeam to work with AHV.
Chevalier
nice partnership Nutanix + Veeam
Wayfarer
We are currently using Carbonite Server Backup (formerly EVault). It's an on-prem or cloud based backup. I like it as I can do a full bare metal backup as well as files, sql, exchange etc backups. I have not tested restoring a bare metal backup to Nutanix. I have in Xen and VmWare and worked great
Wayfarer
I was wondering what your decision points were for choosing HYCU?  It is a standalone option, I imagine you might have other infrastructure needing data protection.  What was the main decision criteria for choosing a point AHV solution?
Explorer
In my case, I was looking at HYCU because we currently use Rapid Recovery for all of our physical servers. As we are virtualizing those server on Nutanix I'm looking at a virtual aware backup that works well with Nutanix AHV so we aren't backing up VM's with the old style client method. I'll continue to use RR with our physical servers.
Trailblazer
I have an environment that is completely virtualised. Decision points around Hycu were :
Hycu is written using the Nutanix API's and therefore has great integration with Nutanix, that i don think anyone can beat at present.
I also like that Hycu is a standalone app and there is no physical hardware (commvault) or software proxies (veeam) needed.
Price, it was competitively priced
Adventurer
I think there is a fair bit of fud in your post jtempleton. For transparency, I work at Commvault (Now: Customer Support) so take this with the usual vendor bias and skepticism. I have been working with Nutanix since 2015 and having so many solutions to pick from is a tesitment to the success of their platform and awesomeness of the community that has resulted.
You are incorrect on the integration point in your post. Most solutions now are integrating with Nutanix's data protection API. Commvault was the first to provide agentless backups (we believed Smiley LOL) and no, it does not require physical hardware (grab a trial version and see for yourself). Likewise I think our friends at Veeam also provide direct integration now without the use of agents. I even think Veritas has announced or has support using agentless methods.
Sure, we're going to recommend physical when you achieve massive scale - but so will Veeam and other vendors if you need deduplication for any significant size of backup. The difference is that we do not need specialized dedupe hardware appliances at scale as we perform this using software only, where many would prefer you purchased a data domain, StoreOnce or other specialized accellerated appliance to handle larger datasets.
We're switching on the new API framework in our next service pack (3 days away) which will also bring CBT for AHV and Nutanix's much improved API model that does away with the older framework that we worked with Nutanix on since 2015. The old framework was tied to protection domains, so I'm excited to break free of that model and take advantage of all the new goodies.
Hycu does seem like an elegant solution, and I do like the approach, but no need to spread the fud. All of these solutions have completely different value propositions. Lets leave the good people here to try each solution on their own merits and keep the fud to a minimum.
