API
V2 virtual_disks target missing container data for CVM.
SOLVED Go to solution
Trailblazer
The listed target provides null's for the CVM's virtual disk. Is there a default container that is uses?
Below is the top of that response.
  "metadata": {
    "grand_total_entities": 3,
    "total_entities": 3,
    "filter_criteria": "",
    "sort_criteria": "",
    "page": 1,
    "count": 3,
    "start_index": 1,
    "end_index": 3
  "entities": [
      "virtual_disk_id": "00055148-f841-31f5-1cf7-246e96180748::9dea5bae-037b-4418-9fa5-54b22ab42bb8:scsi.0",
      "uuid": "bf72d659-3f6f-4c7d-83d3-cc5ff9b1cc50",
      "nutanix_nfsfile_path": null,
      "disk_address": null,
      "attached_vm_id": "00055148-f841-31f5-1cf7-246e96180748::9dea5bae-037b-4418-9fa5-54b22ab42bb8",
      "attached_vm_uuid": "19d98f87-4192-4a19-ae96-3c1435bedb0e",
      "attached_vmname": "NTNX-c36008f1-A-CVM",
      "attached_volume_group_id": null,
      "disk_capacity_in_bytes": null,
      "cluster_uuid": "00055148-f841-31f5-1cf7-246e96180748",
      "storage_container_id": null,
      "storage_container_uuid": null,
      "flash_mode_enabled": null,
1 ACCEPTED SOLUTION
Accepted Solutions
Moderator Moderator
Moderator
Re: V2 virtual_disks target missing container data for CVM.
which virtual disks, specifically, are you looking for?
The CVM itself does not have virtual disks.
VM's within the cluster that users create do have virtual disks.
Jon Kohler | Technical Director, Engineering, Nutanix | Nutanix NPX #003, VCDX #116 | @JonKohler
Please Kudos if useful!
Moderator Moderator
Moderator
CVM's aren't on a storage container, since they install all their volumes bare metal to the first one or two SSD's (depending on your hardware config)
What data are you trying to get at?
Moderator Moderator
Moderator
also what release are you using?
Moderator Moderator
Moderator
And what hypervisor are you using on that cluster as well?
Trailblazer
We're trying to find the container that holds the virtual_disk.
We're using Nutanix 5.0:
* Version 2017.05.22 - Community License
* NCC Version: 3.0.2
* We use the stock hypervistor, AVH. 20170505
Trailblazer
In looking over similar data gathered from the bootstrap class, I see all data populated for storage_container_id,
so perhaps my version is older or limited in some way.
Moderator Moderator
Moderator
